GT 200, 28mm delly, K&N foam filter, and BGM clubman
Posted: Mon Apr 13, 2015 10:41 pm
by Davidsquaredson
Hi,
I am putting the GT kit into my Eibar Jey 200. If any can share a good staring point for the carb set up it would be much appeciated.
My current set up on a stage 4 tune 200cc with 28mm delly, bgm clubman and k&n filter
idle jet: 55
choke = 60
main jet = 120
atomizer=av264
needle x7 with clip in bottom slot
slide 50
3mm float needle
Thanks in advance.
David
Re: GT 200, 28mm delly, K&N foam filter, and BGM clubman
Posted: Mon Apr 13, 2015 10:53 pm
by B-Race Tuning
Does Richards site not give you those details? Or a good starting (safe) point? If not, I'm sure he'll be along dreckly to put you right. S
Posted: Wed May 27, 2015 8:53 pm
by Davidsquaredson
This is what I went with:
idle: 60
choke = 60
main = 138
atomizer = av268
needle x7 with clip in top slot
slide 50
BR8ES plug (using R because I have the heat sensor hooked up to my SIP speedo)
My plug is black, not milk coffee brown and I am finding it a bit stuttery below 3,000 RPM. The stutterning is more pronounced if I am trying to maintain speed, less so if I am accelerating. Once I get above 3000 and into 3rd it just smooths out and runs sweet.
I have little experience with jetting, so not sure what I need to change here. Any suggestions?
Thanks
David
Posted: Wed May 27, 2015 9:27 pm
by Mr G in NYC
Here is what I am running .....on my GT200 kit.
with a BGM pro exhaust........at 4%. for 400+ miles.
I think a 28mm carb is a bit restrictive.....
Also X7 is a lean needle . Try a X13 or X2(richer)
I am running ......
30mm Dellorto
55 pilot
X2 needle top notch with spacer
45 slide (rich)
AV268
135 main jet
300 float needle
IGN timing set at 17 degrees static ( petrol is s**t in the US )
Fitted a sweet breath filter and a NGK 8ES plug this week end as
it was fouling the plug running it open mouthed.
Its rich I know but for the next 300 miles thats how I'm running it.
