Hi,
I am putting the GT kit into my Eibar Jey 200. If any can share a good staring point for the carb set up it would be much appeciated.
My current set up on a stage 4 tune 200cc with 28mm delly, bgm clubman and k&n filter
idle jet: 55
choke = 60
main jet = 120
atomizer=av264
needle x7 with clip in bottom slot
slide 50
3mm float needle
Thanks in advance.
David
GT 200, 28mm delly, K&N foam filter, and BGM clubman
Davidsquaredson
- registered user
- Main scooter: Early Eibar Jet 200
- Contact:
Last edited by Davidsquaredson on Wed Apr 15, 2015 6:43 pm, edited 1 time in total.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
B-Race Tuning
- registered user
- Main scooter: Lambro, GP.
- Contact:
Does Richards site not give you those details? Or a good starting (safe) point? If not, I'm sure he'll be along dreckly to put you right. S
Davidsquaredson
- registered user
- Contact:
This is what I went with:
idle: 60
choke = 60
main = 138
atomizer = av268
needle x7 with clip in top slot
slide 50
BR8ES plug (using R because I have the heat sensor hooked up to my SIP speedo)
My plug is black, not milk coffee brown and I am finding it a bit stuttery below 3,000 RPM. The stutterning is more pronounced if I am trying to maintain speed, less so if I am accelerating. Once I get above 3000 and into 3rd it just smooths out and runs sweet.
I have little experience with jetting, so not sure what I need to change here. Any suggestions?
Thanks
David
idle: 60
choke = 60
main = 138
atomizer = av268
slide 50
Thanks
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Mr G in NYC
- registered user
- Main scooter: SX200
- Contact:
Here is what I am running .....on my GT200 kit.
with a BGM pro exhaust........at 4%. for 400+ miles.
I think a 28mm carb is a bit restrictive.....
Also X7 is a lean needle . Try a X13 or X2(richer)
I am running ......
30mm Dellorto
55 pilot
X2 needle top notch with spacer
45 slide (rich)
AV268
135 main jet
300 float needle
IGN timing set at 17 degrees static ( petrol is s**t in the US )
Fitted a sweet breath filter and a NGK 8ES plug this week end as
it was fouling the plug running it open mouthed.
Its rich I know but for the next 300 miles thats how I'm running it.
I am running ......
30mm Dellorto
55 pilot
45 slide (rich)
AV268
135 main jet
300 float needle
