VBA brake pedal removal
Posted: Sun Apr 12, 2015 8:29 pm
by Hammerite
Chaps ,any suggestions as how to remove the pin that retains the brake pedal on the shaft
Richard
Re: VBA brake pedal removal
Posted: Sun Apr 12, 2015 9:13 pm
by lambro
Hammerite wrote:Chaps ,any suggestions as how to remove the pin that retains the brake pedal on the shaft
Richard
Pull the rubber off, this allows more travel.
Then hopefully, it is still loose and you can grab it with pin nose pliers.
A seal pick to poke from underneath sometimes works,
Worse case is an angle grinder to destroy the pedal and then remove the pin.
Shaun.
Posted: Mon Apr 13, 2015 8:40 pm
by Hammerite
Thanks Shaun
Rich
