VBA brake pedal removal
Hammerite
Main scooter: Sx150
Chaps ,any suggestions as how to remove the pin that retains the brake pedal on the shaft
Richard
lambro
Hammerite wrote:Chaps ,any suggestions as how to remove the pin that retains the brake pedal on the shaft
Richard
Pull the rubber off, this allows more travel.
Then hopefully, it is still loose and you can grab it with pin nose pliers.
A seal pick to poke from underneath sometimes works,
Worse case is an angle grinder to destroy the pedal and then remove the pin.
Shaun.
Hammerite
Main scooter: Sx150
Thanks Shaun
Rich
