pulling away problem?
wayne clayton
having problems with pulling away, the only way it will is to rev its nuts off.
the cables are around the correct way as once i have got going i have sellected all the gears.
the engine is an li 150 with a dave webster 190 kit, the carb is a 30mm amal with;
main 170
needle jet 106
pilot 25
3.5 slide
is it the carb or maybe a gearing problem? i think its running with 16x46
any help would be great :?
J1MS
wayne clayton wrote:having problems with pulling away, the only way it will is to rev its nuts off.
main 170
needle jet 106
pilot 25
3.5 slide
JETTING SOUNDS WEAK...
Ive ran 26mm Amals on similar jetting.... but never on a 30mm
Try 107 needle jet.. 2D1 Needle.. and a main jet nearer to 270... The pilot and slide should be OK... Set air screw Half to One turn out Put the needle on second clip.... These set ups can run on a main jet over 300.. depending on Port timings and exhaust and head
wayne clayton
cheers for that, i will give it a try later, :D
Knowledge
Have you a lightened flywheel?
Martin
compass
Are you sure your gears are set up ok? and your not trying to pull away in second?
Only mention ,cause I done this :roll: Its a worth a double check ;)
Powolotti
old kits, especially 190s, have often very long inlet timing, maybe you check this as well
meet me on Facebook: Michael Powolotti
some of my tuning work:
http://www.facebook.com/pages/Powolotti ... 6938811863
my club:
http://www.wiener-spitzbuam.at
Special X
suggest it's weak in the pilot or progression area. Don't have a clue with Amal jetting but if it had been a Dellorto the pilot and slide would be the culprits.
    Users browsing this forum: Google [Bot] and 24 guests
