GP Electronic Ignition Flywheel Centre
YAMLAM
can an Li Electronic Ignition Flywheel Centre be changed to a Gp type .
i see scooter resto`s sell both, presumably the flywheels are the same . are the centers of the stator the same dims
win or lose have a booze
gaz_powell
yes - the flywheel is the same and the boss outer and holes are the same so totally interchangeable
the difference is the internal diameter (for GP or LI/SX cranks)
are you set up to drill out the old rivets etc ....if not it might be cheaper to find a 2nd hand flywheel
YAMLAM
thanks Gaz. Im ok drilling out the old rivets, used to do it on indian points flywheels,changing the rivets to HT Studs.
