EGT Readings
druist
just fitted my egt meter and was wondering a) how long do they usually take to heat up? b) what is a "normal" temperature?
thanks
drew
RBG
Take it for a run. its instant.
I played with the jets & needle to keep mine below 600C.
druist
mine isnt right then. the electrics are fine the dial lights up. if i put one wire from the sender it shoots around to 800c put both as per instructions the needle does nothing. i have took it out tried another sender as i have two and it just wont move above the zero line. Anyone know what the two lead sensor wires do then i might know whats wrong - does it need earthing?
thanks
J1MS
druist wrote:mine isnt right then. the electrics are fine the dial lights up. if i put one wire from the sender it shoots around to 800c put both as per instructions the needle does nothing. i have took it out tried another sender as i have two and it just wont move above the zero line. Anyone know what the two lead sensor wires do then i might know whats wrong - does it need earthing?
thanks
The wires from the thermocouple have to be wired the right way around is all... if its a dial type gauge the wires for lighting it have nothing "normally" to do with the temperature gauge, other than back lighting....
druist
thanks
