Piston circlips
kevspeed
I have a 62.2 'Asso Werke' 3 ring piston for my TV175 that i have misplaced the circlips for :oops: ,should they be the flat 'Seeger' type,or the 'wire' type??,ive tried looking (even with a magnifying glass) at the profile of the slots,but still cant make out which it should be!,anyone in the definite know?? :?:
Knowledge
Try pushing a bit of Blutac ot Plasticene into the groove and look at the resulting shape of the groove. Don't insert the wrong type of clip into the groove, as the result will be expensive (I am sure you know this, but I repeat it here for others)
Martin
barnsleybilly
Main scooter: Li200
Ive a smashed up three ring asso piston on my desk that i use as a paper weight and it used the wire circlips, its 66.6 if that matters
Yanker
barnsleybilly wrote:Ive a smashed up three ring asso piston on my desk that i use as a paper weight and it used the wire Paper clips, its 66.6 if that matters
Correctio...sorry bout that!
kevspeed
Knowledge wrote:Try pushing a bit of Blutac ot Plasticene into the groove and look at the resulting shape of the groove. Don't insert the wrong type of clip into the groove, as the result will be expensive (I am sure you know this, but I repeat it here for others)
Now why didnt i think of that??,(im sure ill think of a reason later on) :oops:
Many moons ago,i did replace the wrong type of circlips in a piston!!!,the result??????..........................A loud 'bang',and coming to a grinding halt 3 miles from the Lymington ferry!!,no scooter on the Isle of Wight that year for me :cry:
barnsleybilly
Main scooter: Li200
Had me looking to see whether I'd put paperclips in one of my dyslexic moments.
B-Race Tuning
Main scooter: Lambro, GP.
Other than piston, no loss then.
kevspeed
All sorted,'wire type' circlips fitted.
