t5 malossi carb size
Posted: Sat Mar 21, 2015 10:36 pm
by ducksta
Running a 30mm dellorto on my t5 172 reed valved engine, on speaking to a reconised tuner today he recommended to use a 26mm any body else use this size and whats the feed back
Re: t5 malossi carb size
Posted: Sat Mar 21, 2015 10:45 pm
by Yanker
Erm no: Correctly jetted the 30mm will deliver the fuel that the reed dictates: never too much and never not enough with the 30mm (that is what mine has without being ridiculous on fuel consumption ie. 60-70 miles on a tank). What is the rest of your set-up and what is the tuner's logic/explanation?
Posted: Sat Mar 21, 2015 10:49 pm
by ducksta
172 malossi malossi reed 30mm carb fast flow tap ports matched etc by chislespeed revolver exhaust 22 tooth clutch
Posted: Sat Mar 21, 2015 10:50 pm
by ducksta
Tuner reconded 26mm will give better fuel and mid range only losing about 2mph on top end
Posted: Sun Mar 22, 2015 2:35 pm
by mick1
Why not go for the VHST ?
Posted: Sun Mar 22, 2015 6:28 pm
by ducksta
mick1 wrote:Why not go for the VHST ?
dont know out about them mick, i could just swap all the bits into a 26mm delly
Posted: Sun Mar 22, 2015 6:34 pm
by mick1
VHST are the flat side. which is the preferred choice nowadays.
I'm looking at fitting a Mikuni flatslide on my PX, again MIkuni's and other carb's seem to be gaining favour over the Dellortos
Posted: Sun Mar 22, 2015 6:38 pm
by ducksta
do you still have the 28mm delly if so would you sell that m8 pm if yes
Posted: Sun Mar 22, 2015 7:18 pm
by gaz_powell
vhst carbs are a lot more expensive than the phbh range.
I think phbh`s are on the up - lots of TS1 and RB motors running them now - easy to set up and cheap to rejet
