bgm stator rubbing bgm flywheel magnet
WINTERMODEL150
Hi .has anyone been experiencing the bgm stator not fitting snug and central into a mag housing due to being machined under size approximately by 25 thou ,causing lighting coils to rub on the flywheel magnets with the ability to twist a crank under high speed?
Regards
Dean
Sorry, is it the stator or the flywheel that you think is machined undersize?
WINTERMODEL150
rosscla wrote:Sorry, is it the stator or the flywheel that you think is machined undersize?
The stator is machined under size
