GP rear frame grill hole size needed
RobD
I'm looking for a favour, I need the dimensions of the rear frame grill holes and their distance from the centre line of the frame. My Italian GP has been repaired and that part came from an Indian donor which doesn't have the holes and so need to drill them before painting it. I've found the following pic of the area (though it's an SX in the pic). Cheers,Rob
Daggs
First off your picture isn't working.
However I've assumed you mean the large holes that accept the rear frame badge holder.
I measured up my LiS frame i'm working on. The holes are 15mm and the centres are 93mm apart. They are also approx. 12mm UP from the sprint rack area of the frame.
Absolute accuracy is not vital for these holes as i'm sure you are aware.
RobD
That's great many thanks.
