Chrome removal
watto66
Hello all
i have got a late Li 150 which im trying to get on the road it hjs a lot of tatty chrome parts on it IE flywheel cover, tank , toolbox, forks and wheel rims. Can i get these sand blasted so i can etch primer and respray or does it have to be removed professionally.
many thanks
I suspect you'd be cheaper to bin them or stick them on fleabay and source replacements you can paint.
De-chroming can be done by platers, though.
mick1
Main scooter: Li Avanti 225
Just had my hub "de-plated" by blasting.
sunrisemac
Main scooter: Lambretta GP150
I had a similar load of stuff stripped of plating so I could use all the original bits on my restoration but it cost a fair bit, the bits made of cast ally I spent ages scratching off with a diamond file.
fairspares
ive taken chrome parts in the past to a powder coaters that also do sand blasting , although it dosnt remove all the chrome you wouldnt know there was chrome underneath and they have lasted a good few years without any problems, also you can spray over the powder coat or take to a chrome platers for dechroming.
watto66
Thanks chaps I'll try the sand blast route first
