Page 1 of 2
Barrel Base Sealing
Posted: Sat Feb 28, 2015 9:28 pm
by Starwave
Hello
To set the squish on my Lamby I'd like to fit a 1mm head gasket and omit a base gasket.
So.......should I use Blue Hylomar or clear silicone (Dow Corning 732) on the base of the barrel? Tis a Rapido 225 if it makes any odds.
Apologies if this has been discussed at length before.
cheers
Re: Barrel Base Sealing
Posted: Sat Feb 28, 2015 9:36 pm
by rosscla
Loctite copper silicon 5290
Posted: Sun Mar 01, 2015 1:38 pm
by handofdave
rosscla wrote:Loctite copper silicon 5290
thats what i use too
Posted: Sun Mar 01, 2015 2:07 pm
by Starwave
Super job, in which case I shall use it too.
Cheers gents
Posted: Sun Mar 01, 2015 2:20 pm
by Muppet
Posted: Sun Mar 01, 2015 4:12 pm
by shamrockexpress
High temp hermitite red never fails for me although its now hard to find!!!!!not sure if its discontinued or superceeded with a new product maybe some others on here know were to get it........
Posted: Sun Mar 01, 2015 4:33 pm
by rosscla
Posted: Sun Mar 01, 2015 6:42 pm
by bazza3004
never had a problem when using clear silicone . don't think the blue hylomar actually sets .
Posted: Sun Mar 01, 2015 9:33 pm
by Starwave
I think 5290 was a typo, and was meant to be 5920. Picked some 5920 up today from Halfrauds.
Ai, blue Hylomar doesn't set, which is one attraction when pulling things apart, but its gap filling properties aren't as good as silicone. Easy to get the two components apart and clean up. Silicone sets even before clamping the faces together as it's moisture in the air that sets it off.
I mentioned blue Hylomar and Dow Corning 732 clear silicone as they were the two most likely looking sealants in me garage.
Thanks for the PM.
Posted: Sun Mar 01, 2015 10:38 pm
by rosscla
Yes, my typo, sorry.
