Fitting s2 ignition switch
woody
Hi , i,m looking to fit a series 3 a/c key ignition on my standard series 2 with standard light switch , does anybody have a wiring diagram for this please ?
HxPaul
I have a series 2 running on an Indian 12v system.I use a 3 position ignition switch and just use the handlebar switch for dip,main beam and horn.The handlebar switch is an after market switch so the wiring will be different to the original one,but the idea will be the same.
Paul
DigDug
Green from CDI to Green (hopefully) on the ingintion switch then earth the earth lead which was pink on my switch.
You can bin the rest.
Did you have to do that?
woody
cheers chaps i'll give it a go
    Users browsing this forum: Semrush [Bot] and 12 guests
