Setting up a 30mil carb
Posted: Wed Feb 11, 2015 10:42 pm
by frankie
I have fitted a 175cc stage four alloy barrel kit with a 30 mil delly carb and GP crank on my 125 series two with a AF big bore pipe.
The scooter just bogs down when i try to open the throttle i'm going to fit a Taffy replica pipe anyone running the same set up any advice would be appreciated.
Thanks.
Re: Setting up a 30mil carb
Posted: Thu Feb 12, 2015 12:46 am
by rosscla
Does it run ok at lower throttle openings and bog when you open it up?
What jets / needle you got in there?
Posted: Thu Feb 12, 2015 9:51 am
by Daggs
One small bit of advice. Decide which exhaust you WANT on it. Take the jetting from there. Costantly swapping pipes just makes a tricky job much trickier.
Without a dyno, jetting will take a while, but it can be done.
Posted: Thu Feb 12, 2015 10:35 am
by Donnie
It can easily be done! As daggs says, pick a pipe, stick to it and learn to jet, it's p155 easy though a little time consuming.
You'd be daft putting a newly built, not run in engine on a dyno frankly.
