Jockey Boxenstop rear brake
Shuggie
Are these worth fitting? Any one know if any UK dealers have these in stock?
Shuggie
thanks for that Toddy , anyone know if any UK Dealers stock them?
DigDug
Get them from Jockey's, very simple, very quick.
And yes they work if you have the patience to set them up correctly.
Did you have to do that?
I Think Cam Lam do and Chiselspeed have some items
Timbo
I was going to fit one some time back but a post on here put me off...
Darrell Taylor was advertising them on FB last week
Adyonekenobi
Main scooter: Li150 Special, now TS1 225cc
I got one direct from Jockeys.
Works well, my rear brake is much better than it was, I do have an Indian casing, there is a known issue with rear brake shoe mounting points and the Jockeys kit cured that problem.
I did change the bolt supplied from,I think 6mm to 8mm and have had no problem.
Spanner check the running gear before every outing, like in the Army. You know it makes sense!
