I have fitted a 175cc stage four alloy barrel kit with a 30 mil delly carb and GP crank on my 125 series two with a AF big bore pipe.
The scooter just bogs down when i try to open the throttle i'm going to fit a Taffy replica pipe anyone running the same set up any advice would be appreciated.
Thanks.
Setting up a 30mil carb
- registered user
- Main scooter: Lambretta
- Contact:
Does it run ok at lower throttle openings and bog when you open it up?
What jets / needle you got in there?
One small bit of advice. Decide which exhaust you WANT on it. Take the jetting from there. Costantly swapping pipes just makes a tricky job much trickier.
Without a dyno, jetting will take a while, but it can be done.
Donnie
- registered user
- Main scooter: Lambretta Eibar Series 2
- Contact:
It can easily be done! As daggs says, pick a pipe, stick to it and learn to jet, it's p155 easy though a little time consuming.
You'd be daft putting a newly built, not run in engine on a dyno frankly.
Donnie.
