Koso fuel gauge
sydduckett
anyone used one of these Koso gauges or know where I can get a resistive sender that will work with it. I don't think one exists that's also a tap so I'm presumimg the tank will have to be drilled.
http://www.sip-scootershop.com/en/produ ... koba003230
thanks
Sef
jonashford
Just buy a fuel gauge from a boat, faria do them matching sender shud cost u less than £60
diesel
I installed one of these with a faria gauge and it works well. It meant drilling a hole in the tank for the float to fit through and six pilot holes for self tappers but its all neat and the unit itself seals the tank back up with a gasket. It fits snugly behind the filler and there was plenty of room for it under the arch. I bought the 17cm probe which shows empty with a litre or so left in a series one tank. Its from ASAP supplies they're a marine supplier. You have to match resistance with the gauge,they do US and Euro resistance gauges and senders £62 delivered for the pair
    Users browsing this forum: No registered users and 86 guests
