carb position
Posted: Sun Jan 18, 2015 4:53 pm
by ducksta
T5 172cc engine 30mm carb sat on top of a malossi reed valve, in the original frame the carb faced forward but the Frame it is going in i can reverse it to face backwards will this change the performance.
Re: carb position
Posted: Sun Jan 18, 2015 8:46 pm
by ducksta
anyone
Re: carb position
Posted: Sun Jan 18, 2015 9:18 pm
by ducksta
position at present
Re: carb position
Posted: Mon Jan 19, 2015 1:19 am
by coaster
Personally I would leave it facing forward, just thinking that hung out the back it will be sucking in exhaust fumes and other shite kicked up by the rear wheel.
Re: carb position
Posted: Mon Jan 19, 2015 9:37 am
by lambro
ducksta wrote:
position at present
If the manifold is matched to allow it to flow properly I don't see why you can't.
I have a 25mm on this:
And an SS90 rep with a rear facing 32mm, both work fine in the wet as well
Re: carb position
Posted: Mon Jan 19, 2015 11:46 am
by OzOAP
No problem running backwards. My TS1 P Range has a rear facing carb.
The Quattrini 172 kit also does.
Re: carb position
Posted: Mon Jan 19, 2015 3:15 pm
by ducksta
will check it out if it looks ok, then rear facing it will be
Re: carb position
Posted: Mon Jan 19, 2015 5:29 pm
by coaster
You might also want to consider the access to the adjustment screws just in case the shock gets in the way
