Nu205/2205
Posted: Mon Jan 05, 2015 11:43 am
by Ihateyoubutler
I've been told that you can use the wider nu2205 mag side bearing without issue on an li/sx type crank (obviously also not using the mag housing spacer ring). Is this right? Anyone doing this as the wider bearing has to be better.
Thanks.
Re: Nu205/2205
Posted: Mon Jan 05, 2015 1:38 pm
by hendy
you need to use a gp crank with that bearing
Re: Nu205/2205
Posted: Mon Jan 05, 2015 1:59 pm
by Ihateyoubutler
hendy wrote:you need to use a gp crank with that bearing
Why?
Re: Nu205/2205
Posted: Mon Jan 05, 2015 2:57 pm
by barnsleybilly
I understand that the drive side oil seal shoulder on the GP200 crank is shorter then the SX/Li crank to allow this bearing to be used.
Re: Nu205/2205
Posted: Mon Jan 05, 2015 3:09 pm
by hendy
Why?
To be completely honest, I can't remember, but I did mine a couple of months back and remember that you can't, but not exactly why.
Billy from Barnsley offers a reason, so I'm just going to agree with him.
As the saying goes, "A little bit of knowledge" ........................
Re: Nu205/2205
Posted: Mon Jan 05, 2015 3:17 pm
by barnsleybilly
is a dangerous thing .....lol
Re: Nu205/2205
Posted: Mon Jan 05, 2015 8:20 pm
by Grumpy225
barnsleybilly wrote:I understand that the drive side oil seal shoulder on the GP200 crank is shorter then the SX/Li crank to allow this bearing to be used.
That is correct. The alignment of the bearing to the race will be off if you use the GP bearing on a LI crank. You would need to machine the seal shoulder down on the crank to make it all line up. Cheaper to just buy the correct bearing.
