Nu205/2205
Ihateyoubutler
I've been told that you can use the wider nu2205 mag side bearing without issue on an li/sx type crank (obviously also not using the mag housing spacer ring). Is this right? Anyone doing this as the wider bearing has to be better.
Thanks.
hendy
you need to use a gp crank with that bearing
Ihateyoubutler
hendy wrote:you need to use a gp crank with that bearing
Why?
barnsleybilly
Main scooter: Li200
I understand that the drive side oil seal shoulder on the GP200 crank is shorter then the SX/Li crank to allow this bearing to be used.
hendy
Why?
To be completely honest, I can't remember, but I did mine a couple of months back and remember that you can't, but not exactly why.
Billy from Barnsley offers a reason, so I'm just going to agree with him.
As the saying goes, "A little bit of knowledge" ........................
barnsleybilly
Main scooter: Li200
is a dangerous thing .....lol
Grumpy225
barnsleybilly wrote:I understand that the drive side oil seal shoulder on the GP200 crank is shorter then the SX/Li crank to allow this bearing to be used.
That is correct. The alignment of the bearing to the race will be off if you use the GP bearing on a LI crank. You would need to machine the seal shoulder down on the crank to make it all line up. Cheaper to just buy the correct bearing.
