Any suggestions/advice/help much appreciated
Oh, and a HAPPY NEW YEAR!!!
Thanks Rosscla, I'm tempted to have a go at fitting the Li ramp, would I have to take the end plate out to remove the bit that needs removing or would I be able to do it in situ?rosscla wrote:For the GP shaft there's no way to pre-tension the spring before you fit the casing because the ramp is on the end plate rather than the casing. I used to clamp my mole grips on it and use them to rotate the shaft as I fit the casing. You can use the pedal but I find that awkward. Now I convert them to use an Li style ramp.
Too late, shes 'buttoned' up! Been out for a spin and all appears well, no noises, slips or anything untoward...........fingers crossed!!!tavspeed wrote:might be worth checking it isn't catching on the clutch top plate,before you finally button it up.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
