Page 1 of 3
Pull down or push up?
Posted: Sat Dec 27, 2014 5:22 pm
by dave411
Chain guides,pros and cons?
I am thinking of a push up,no reason other than i think it will give the chain an easier life :?:
Re: Pull down or push up?
Posted: Sat Dec 27, 2014 5:30 pm
by Timbo
I asked this question on another forum recently, push down if your changing chains/sprockets regularly....
Posted: Sat Dec 27, 2014 8:11 pm
by shocky
I got a scootrs push up one andthe bottom slippy nylon one guess what didnt fit .. :D
actually I cut a few bits here and there then it did for what it cost was ok
Posted: Sat Dec 27, 2014 8:47 pm
by dave411
Where did you buy it?
Posted: Sat Dec 27, 2014 9:10 pm
by bolzenanker
I use the Jockeys Boxenstop one without a lower guide. Always works, never had a problem.
Posted: Sun Dec 28, 2014 7:46 am
by Donnie
Posted: Sun Dec 28, 2014 9:39 am
by yozzer
I've used a pull down one for years with no bottom guide with no problems, means you have more adjustment and can use a longer chain, the tension is on the bottom so just the slack at top.
Posted: Sun Dec 28, 2014 10:33 am
by bolzenanker
Yes Donnie, that's the one.
Posted: Sun Dec 28, 2014 11:27 am
by Donnie
I've been put off those ones and have gone for the richard taylor one instead which are about the same price(within a quid or two)
Posted: Sun Dec 28, 2014 11:33 am
by shocky
dave411 wrote:Where did you buy it?
Direct from scootrs I did however expect to make it fit
