Pull down or push up?
dave411
Main scooter: Li 125
Chain guides,pros and cons?
I am thinking of a push up,no reason other than i think it will give the chain an easier life :?:
Timbo
I asked this question on another forum recently, push down if your changing chains/sprockets regularly....
I got a scootrs push up one andthe bottom slippy nylon one guess what didnt fit .. :D
actually I cut a few bits here and there then it did for what it cost was ok
dave411
Where did you buy it?
bolzenanker
Main scooter: Spanish S2 Li150 1963
I use the Jockeys Boxenstop one without a lower guide. Always works, never had a problem.
Donnie
Donnie.
yozzer
Main scooter: gp200
I've used a pull down one for years with no bottom guide with no problems, means you have more adjustment and can use a longer chain, the tension is on the bottom so just the slack at top.
bolzenanker
Yes Donnie, that's the one.
Donnie
I've been put off those ones and have gone for the richard taylor one instead which are about the same price(within a quid or two)
Donnie.
dave411 wrote:Where did you buy it?
Direct from scootrs I did however expect to make it fit
