BGM225 carb set up
Servetta200
Main scooter: Serveta jet 200
Im buildng a motor BGM 225 motor running a dellorto 30mm carb with a JL full race pipe,
Have any of you got the same set up as im looking for carb settings and Jet sizes.
Hope you can help guys
Timbo
There's a lot of info on MB site...I have a 28 Delly on mine..
Servetta200
I looked on the MB site but they give two or three options for each jet and needle etc.
I was hoping some one might have the same set up so I had a starting point.
Start at the higher end of the ranges in the MB advice and work down till you get it right. Better rich than lean
ForemanBob
Main scooter: GP RT230
60mm crank, PHBH 30mm with Breathsweet Filter, JL3 Curly exhaust.
70 Choke
55 Pilot
40 Slide
X7 Needle clip at 3 (to richen up 1/4 throttle)
AV264 Atomiser
122 main (on the rich side)
