Flywheel help please
thackers
Just getting round to swapping the centre boss from a Vega to a modern A.F lightened flywheel, and in my haste i forgot to note where the keyway sits :oops: Will it be the same position as a original A.F Ducati wheel?
I think if so it will sit around the 8 'O' Clock position or are they all diffrent and dependant on something where the magnets sit? :oops: :oops: :oops: :oops:
original A.F Flywheel
Boss temp fitted
That looks right from memory. What bolts have you used David? The new AF bosses are radiused where the bolt head sits inside the flywheel, I used cheese head type for clearance but they sat on the radiused edge so I had the grind the diameter of the heads smaller on each bolt. Though looking at the clearance on the nut heads on yours that may not be an issue. I did drill them out to 6mm though.
