Gear control shaft bush
bristolmod
The one where the gear control rod enters the crankcase just above the gear box area.
To cut a long story short, my mates LI has problems engaging neutral when stationary. We've tracked it down to wear in the bush area, which allows the rod to rock back and forth a tad, thus screwing up the selector mechanism.
Whilst moving, all gears select very nicely and its easy to put it into neutral whilst approaching a junction or lights etc.
My question is- can the bush be replaced with the engine in-situ and without striping down the gearbox? Its the earlier type gear box selector with the splined and bolted top mechanism.
It would appear that I simply remove the pinch bolt and lift off the top part, then ease out the bush (you can see it moving). The replace with a new bush and put the top mechanism back on.....................................
Surely a job on a Lambretta can't be this easy...........
Any advice Gents?
best
Chris
Scootering since 1968.
RBG
If its lose & you can get it out great.
the trouble is getting the new one in with the control shaft in place.
you often need a 12mm reamer to fit a new one.
carlos fandango
Pull mine out and back in with some all thread and various washers and bolts ;)
