Page 1 of 2
[SIGH] That moment when you have started an engine build ...
Posted: Thu Nov 27, 2014 6:35 pm
by Donnie
Re: [SIGH] That moment when you have started an engine build
Posted: Thu Nov 27, 2014 11:15 pm
by ArmandTanzarian
Makes you glad to be alive don't it!
Posted: Fri Nov 28, 2014 12:14 pm
by corrado
Had my moment a couple of weeks ago, I finally decided to rebuild the Jet 200 engine from it's bare casing. First job remove some of the worn studs, I thought I won't feck around with double nutting etc, I'll go straight in with the stud remover. First stud I tried snapped off with a nice clean break flush with the casing. Arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh feck!!!
Posted: Fri Nov 28, 2014 12:28 pm
by bristolmod
if only you lot had actually gone to Sunday School when your mothers sent you when you were young instead of bunking off!!
Karma.
Posted: Fri Nov 28, 2014 7:20 pm
by Donnie
ArmandTanzarian wrote:Makes you glad to be alive don't it!
LOL
Posted: Fri Nov 28, 2014 7:22 pm
by Donnie
corrado wrote:Had my moment a couple of weeks ago, I finally decided to rebuild the Jet 200 engine from it's bare casing. First job remove some of the worn studs, I thought I won't feck around with double nutting etc, I'll go straight in with the stud remover. First stud I tried snapped off with a nice clean break flush with the casing. Arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh feck!!!
oh bugger
Luckily im starting with a clean casing without a single stud in it so at least i wont have that particular problem.
On the plus side Ive decided to use some donor parts from my old chopper engine that has been laying in the corner for a couple of years and the gearbox is indeed li150 as hoped
Posted: Fri Nov 28, 2014 10:10 pm
by Muttley McLadd
bristolmod wrote:if only you lot had actually gone to Sunday School when your mothers sent you when you were young instead of bunking off!!
Karma.
WTF??
Posted: Fri Nov 28, 2014 11:03 pm
by rosscla
Been on the communion wine ...
Posted: Sat Dec 06, 2014 6:25 pm
by Trojan
Repent you hapless Souls,
that communion wine must taste bad as they always give a piece of bread to get rid of the taste, Chris is that a hint for christmas wants list
Posted: Sat Dec 06, 2014 6:42 pm
by bristolmod
if you've ever wondered why choir boys always have their hair parted in the middle......................
