[SIGH] That moment when you have started an engine build ...
Donnie
..... and the drive bearing decides it's going in cockeyed and 2 of the rear hub plate studs strip the threads off the casings at only half the torque they should be at and then you find your helicoil bit is broken from the last time you used it :? :?
Ah well, onward and upwards! :D :D
Donnie.
ArmandTanzarian
Makes you glad to be alive don't it!
Had my moment a couple of weeks ago, I finally decided to rebuild the Jet 200 engine from it's bare casing. First job remove some of the worn studs, I thought I won't feck around with double nutting etc, I'll go straight in with the stud remover. First stud I tried snapped off with a nice clean break flush with the casing. Arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh feck!!!
bristolmod
if only you lot had actually gone to Sunday School when your mothers sent you when you were young instead of bunking off!!
Karma.
Chris
Scootering since 1968.
Donnie
ArmandTanzarian wrote:Makes you glad to be alive don't it!
LOL
Donnie.
Donnie
corrado wrote:Had my moment a couple of weeks ago, I finally decided to rebuild the Jet 200 engine from it's bare casing. First job remove some of the worn studs, I thought I won't feck around with double nutting etc, I'll go straight in with the stud remover. First stud I tried snapped off with a nice clean break flush with the casing. Arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh feck!!!
oh bugger :-(
Luckily im starting with a clean casing without a single stud in it so at least i wont have that particular problem.
On the plus side Ive decided to use some donor parts from my old chopper engine that has been laying in the corner for a couple of years and the gearbox is indeed li150 as hoped :-)
Donnie.
bristolmod wrote:if only you lot had actually gone to Sunday School when your mothers sent you when you were young instead of bunking off!!
Karma.
Chris
WTF?? :shock:
Been on the communion wine ...
Trojan
Main scooter: LAMBRETTA INNOCENTI
Repent you hapless Souls, :lol: that communion wine must taste bad as they always give a piece of bread to get rid of the taste, Chris is that a hint for christmas wants list :lol: :lol: ........ 8-)
bristolmod
if you've ever wondered why choir boys always have their hair parted in the middle......................
