Clear Coating a Vespa Fuel Tank....
cartmel808
I've got a new (re-made) Vespa Fuel Tank for a winter project - its currently in bare (oiled) steel, so I quite fancy having it done in a clear coated finish - rather than painted as per the rest of the scooter...
Anyone got any recommendations on what the best method/type of clear coating process to use on a fuel tank?
Cheers - Graham.
GLscoot
Main scooter: Vespa GS150
Get it blasted, then spend a few hours with wire brush on grinder to get the finish you want, then get it clear lacquer powder coat. Don't powder coat straight after sand blasting, it will turn out greenish.
cartmel808
Cheers for that Gary... Its already bare metal - so just need to give it a de-grease & a bit of a sand. :D
GBCS
Main scooter: Lambretta GP RB250
GLscoot wrote: Don't powder coat straight after sand blasting, it will turn out greenish.
Not a problem I've come across !. In my experience, rust will always spider under the clear coat. Unless you use one of the specialist House of Kolor, or Alsa clear coats.
GLscoot
Through experience I have to agree, rust now all over my scooter, adds to the look, but Im sticking with it for another year.
