Laboured Tick Over when Hot
Posted: Sun Nov 16, 2014 3:04 pm
by Lamaddict
The scoot runs great but I'm concerned at the slow, laboured tick over when I slow down, throttle off at the lights or wherever. It only happens after it heats up, it eventully goes back to normal. Running a 28 Dellorto, SIL MB210 with a BGM V1 exhaust. It might be the pilot jet but I had to change that to make it start better. Any other options/ideas?
Re: Laboured Tick Over when Hot
Posted: Thu Nov 20, 2014 9:30 pm
by Lamaddict
I thouight someone might have also experienced this, tick over very slow when throttling off, only when hot.
Posted: Thu Nov 20, 2014 10:50 pm
by sunrisemac
sounds like it might be going a bit rich when you throttle off then takes a while to lean off, have you increased size of pilot jet?
Posted: Fri Nov 21, 2014 9:37 am
by Daggs
Have you tried adjusting the carb air/mix screw when hot?
