Laboured Tick Over when Hot
Lamaddict
The scoot runs great but I'm concerned at the slow, laboured tick over when I slow down, throttle off at the lights or wherever. It only happens after it heats up, it eventully goes back to normal. Running a 28 Dellorto, SIL MB210 with a BGM V1 exhaust. It might be the pilot jet but I had to change that to make it start better. Any other options/ideas?
Lamaddict
I thouight someone might have also experienced this, tick over very slow when throttling off, only when hot.
sunrisemac
Main scooter: Lambretta GP150
sounds like it might be going a bit rich when you throttle off then takes a while to lean off, have you increased size of pilot jet?
Daggs
Have you tried adjusting the carb air/mix screw when hot?
