So,what caused this then??
kevspeed
Bog standard GP150,no air leaks,jetted correctly,running fine (well,for the past 6 months anyway)
Luckily only travelling at 35-40 when it happened!! :o
Mr G in NYC
Main scooter: SX200
F++K me thats nasty....cranks snapped nasty ...piston seized and twisted and snapped
the crank.... did you forget to mix oil in the petrol ? or changed down from 4th
to first at 50 mph by mistake ? :shock: G
kevspeed
Mr G in NYC wrote:F++K me thats nasty....cranks snapped nasty ...piston seized and twisted and snapped
Not me (fortunately),one of the local feller's,luckily no one hurt,except the wallet!
Mr G in NYC
Main scooter: SX200
Phew....... thank god he didn't come off like .........G
Ouch, looks like a twisting type break rather than a straight fatigue, hard to see in the pictures but is there shims in the crank or on the piston? Does the small end still move?
If it's an original crank it could just be age.
Yanker
SIL rod failure due to excessive piston to bore clearance (evidence the blow-by), Ring failure (where is the top one). Small-end bg failure: check as suggested by roscalla. Pics are poor: check big-end and main bearings. Coupled with poor quality components?
carlos fandango
Bad fuel ? ......lol
scooterslag
kevspeed wrote:Image
Nasty as f@@k :o be interested to see what you can find out about this
The mack daddy on the left!
dave411
Main scooter: Li 125
Seen this on two stroke outboards.Normally so much damage it hard to diagnose,but we think it's a piston seizeure caused by detonation,never lack of oil or over heating,as the engine still runs ok,but only on five cylinders.
kevspeed
Yanker wrote:SIL rod failure due to excessive piston to bore clearance (evidence the blow-by), Ring failure (where is the top one). Small-end bg failure: check as suggested by roscalla. Pics are poor: check big-end and main bearings. Coupled with poor quality components?
Top ring is present,small end is still free,mains are good,mostly suprised at the chunk of barrel spigot thats smashed off,and the fact that the engine casing isnt damaged!
Original 1979 Indian 150cc motor,no modifications except for a 12v electronic,as the lights on the original points set up were dire!,pity as was running faultlessly,still,its Lambretta isnt it!
    Users browsing this forum: Amazon [Bot] and 4 guests
