JL/asian copy end can replacement
Posted: Mon Oct 06, 2014 11:48 pm
by Muttley McLadd
Does anyone make a bracket to fit one of these:
Onto one of these, instead of the one that's on it:
ta
Re: JL/asian copy end can replacement
Posted: Tue Oct 07, 2014 12:47 pm
by GLscoot
I take it your rubber section has perished. When i had this exhaust i used a nylon spacer of similar size drilled all the way through and used a 6mm bolt with penny washers. I think I got it out of b&q or halfords.
gary
Posted: Tue Oct 07, 2014 4:01 pm
by goldeneye
use a vespa rear shock silent block and a bit of stud, couple of nuts and washers and jobs a gudun.
Posted: Tue Oct 07, 2014 5:47 pm
by Muttley McLadd
Nah.. there's nothing wrong with the stock one. It just looks and sounds a bit s**t/asian.
Posted: Wed Oct 08, 2014 3:16 pm
by GLscoot
i take it its the end can you want to change, I thought it was the fixing bracket to the rear shock. Post the dimensions of the fixing points and I will see if its the same as the JL end can.
Gary
Posted: Fri Oct 10, 2014 10:26 am
by soosh
