JL/asian copy end can replacement
Does anyone make a bracket to fit one of these:
Onto one of these, instead of the one that's on it:
ta
GLscoot
Main scooter: Vespa GS150
I take it your rubber section has perished. When i had this exhaust i used a nylon spacer of similar size drilled all the way through and used a 6mm bolt with penny washers. I think I got it out of b&q or halfords.
gary
goldeneye
use a vespa rear shock silent block and a bit of stud, couple of nuts and washers and jobs a gudun.
Nah.. there's nothing wrong with the stock one. It just looks and sounds a bit s**t/asian.
GLscoot
i take it its the end can you want to change, I thought it was the fixing bracket to the rear shock. Post the dimensions of the fixing points and I will see if its the same as the JL end can.
Gary
soosh
    Users browsing this forum: Baidu [Spider] and 2 guests
