Polini 221
Jay63
Main scooter: Px200
Hi , im getting all the parts together for my polini 221 , so far I have purchased the 221 kit , a mazzy 60mm crank , I'm not sure about the crank but if everyone says its not the best I will swap it , a sip road 2 exhaust and all new bearings and gaskets , next on my list is the clutch and carb , this is where I need advise , I'm looking at bgm superstrong with a 24 tooth drive , will this be any good ? I'm after a torquey touring set up , will I need a shorter 4th gear (t5) as for the carb I was thinking of a 26/26 with polini Venturi kit , any help or suggestions guys , I just want to get it right , thanks
bazman
Pinasco crank, no t5 4th needed and would stick with 24mm with normal filter.
Built a mates engine with this set up and it was a torque monster and would really fly along also up the arses of gts 300's !!
Juan
What about Polini's own crank? A bit more expensive than the Pinasco but more inlet timing or you could go with Pinasco's 62mm item which is a bit more expensive again with further inlet timing.
1469leach
Main scooter: jet200/rapido 225
SCK have an article on building this very engine on their blog site,from memory they used a 24t clutch cog and polini crank with a standard gear box.They included a dyno in the article and it topped out at around 6000 rpm and 26 nm of torque I think.
Cheers Jeff
1469leach
Cheers Jeff
Jay63
Main scooter: Px200
1469leach wrote:SCK have an article on building this very engine on their blog site,from memory they used a 24t clutch cog and polini crank with a standard gear box.They included a dyno in the article and it topped out at around 6000 rpm and 26 nm of torque I think.
Cheers Jeff
Do you have a link to the SCK blog , I googled but can't find it , thanks :-)
Possibly this one.
Jay63
Main scooter: Px200
Muttley McLadd wrote:Possibly this one.
Thanks for that , very interesting read
H,POOL GADGE
Sean Brady built my polini 220 and for once I have a torquey, economical, RELIABLE tourer! well impressed and pleased....24mm spaco-idle jet 48/100, main stack-140-B3-128 no holes in filter and carb inlet cut by Sean, casings matched to polini barrel by Sean, reprofiled head-10:1, squished-1.4, packer 1.5, pinasco crank 60mm and cut by Sean, cosa banded, malossi springed clutch, standard 4th gear cog, JL pipe, dynode 19bhp-17 torque...cruises 60 economically and with ease and av seen 85 twice and backed it off.....
1469leach
Gadge,have you had any malossi 210 long stroke motors?How does the polini compare?
Cheers Jeff
