vespa t5 clutch
ducksta
need a complete clutch with 22 teeth for my t5 malossi/reed valved motor 18.5bhp-whats the best clutch for the job
paul d
Main scooter: T5 172 Tv 240
On my 172 I've fitted a polini 4 plate conversion with a 22 tooth cog and new brass bits to the original 20 tooth clutch. Was fed up of having cosa clutch probs and decided on one last cheap fix before splashing out on one of the expensive solutions. My 172 doesn't have a reed conversion but pulls the 22tooth. The polini set up has been brilliant. Stronger springs but easy to use. Worth trying.
