Series 2 rebuild
dapper
Will the CDi fit where the original coil went on the frame without fouling on the side panel? I have the electronic mounting kit, but it appears the regulator won't fit due to the round frame support under the frame loop, so where do you guys mount you regs? I thenk yew :D
LI150
Main scooter: Series 2 LI150
Get the mounting bracket that sits at the back of the frame cant remember who sells them try ebay?
jazzyb
Scooter restorations do them
gaz_powell
I used a s2 mounting kit
