RB20 + LTH/Jimmers manifold
ArKaTxU
Hi.
RB20 + this manifold and PHBH30 fits under sidepanel in a jet200?
Thanks!
ArKaTxU wrote:Hi.
Thanks!
I cannot be certain with an RB but I'm using an LTH short manifold on a TS1 and it fits under an LiS slimstyle panel with a GP or Breathsweet elbow and remote filter BUT I am using a BGM PWK 30mm carb which is about 20mm shorter than a PHBH. The Mikuni is another short option.
jonashford
i use a rb lth manifold with a tmx 35 on sx panels there is loads of room, but there was plenty with the std manifold as well
ArKaTxU
coaster wrote:
ArKaTxU wrote:Hi.
Thanks!
In ScooterCenter catalog they say that BGM PWK 28/30 have 85mm and PHBH 90mm. Its correct? Because if BGM PWK 28 have 70mm I think that is a good option too.
jonashford wrote:i use a rb lth manifold with a tmx 35 on sx panels there is loads of room, but there was plenty with the std manifold as well
Yes, I have used TMX35 but I want something smaller this time.
Thanks!
ArKaTxU wrote:[.....In ScooterCenter catalog they say that BGM PWK 28/30 have 85mm and PHBH 90mm. Its correct? Because if BGM PWK 28 have 70mm I think that is a good option too.
I'll measure a PWK and a PHBH for you when I get up to Norfolk in an hour or so just to make sure ;)
ArKaTxU
;-) Thanks!
PWK measures 83mm
PHBH bare measures 90mm
PHBH with plastic bell mouth measures 97mm
I was a bit out with my previous guesstimate :oops:
ArKaTxU
;) no problem
Thanks
    Users browsing this forum: Amazon [Bot] and 1 guest
