Standard Petrol Tap Flow Rate?
Tom Russell
What's an acceptable amount of fuel to flow from a standard tap, in 1 minute, for a 20mm carb on standard 150 engine??
Maybe someone, whose scoot runs fine, would test this for me?
dapper
I understand that from a fast flow petrol tap, the flow should be around a pint in one minute. So for a standard tap, somewhat less than that, although I believe you could drill out the orifices a little to improve the flow rate from a standard tap.
Tom Russell
Thanks dapper, but I'm specifically interested in the acceptable flow rate from a standard tap, cheers :-)
