front sprocket question
rainbowrunner
Main scooter: Series 2, RT 195
Hi all, got a golden special with a steel 175 kit, 42 mm clubman, carb is one of those reworked jettex from cam lam, 120 main jet BR9 plug, runs great but feel it could do with upgearing a wee bit.
its running 46 crown & 16 front sprocket , if i fitted a 17 front sprocket would it pull it ok ? just asking before i get a new 81 link chain :?
many many thanks
Does it pull strongly in fourth but seem to be revving hard flat out ?
If so it might stand an extra tooth, you don't say what gearbox is in there?
rainbowrunner
rosscla wrote:Does it pull strongly in fourth but seem to be revving hard flat out ?
thats correct, it pulls great but get to 60 mph its reving like mad, its a 150 box and its got a TV con rod
If you have an idea what it's revving out at try one of the gearbox calculators
http://avantone.wordpress.com
http://www.scooterhelp.com/tuning/lam.gear.calc.html
Might give you an idea of what to expect for the effort / expense.
rainbowrunner
thanks for the replies lads, I already have a 17 sprocket so i just need a chain for £45 (IWIS) so i think its worth a try ;) going to austria next year, so just trying to give the engine a bit more get up and go without screwing it
