P2 winter treat
gaz_powell
Just posted some pic on VCB forum - can't post pics on here as I don't have a photo host
http://www.vespaclubofbritain.freeforum ... otos-added
Not sure if the link will work - I think you have to be a member on VCB even to look
Its some shots of my new harry barlow tuned autisa 200 cylinder part of my winter treat for P2 - sip road pipe + new top end
Probably not many people know or have seen the autisa kits and the port layout. Ali barrel with steel liner - not to be confused with the poor indian ones availble now. Great kits although the pistons were prone to chuck ring pegs - as I found out on my first one. I've got 4 barrels in various forms - standard with gen piaggio piston, mildly tuning on 1st oversize using a meteor piston (soon to be removed) , the HB one with SIP GS piston and another with a score in it which will need to be taken out to 68mm but that's for another day.
Hopefully someone may post them on here - if not I just delete the post
Gaz
ove
Gaz, it won`t let me open the link, it says I haven`t permission to view this thread.
gaz_powell
ove - I thought this might happen - it looks like you have to be a member of the VCB forum to even view
Shame
Gaz
Norrie Bodge
Gaz
Upload ya pics to photobucket then you can
add your links to here for members to view
gaz_powell
I`m signing up to anything else !!! I ve had enough of passwords and 4 digit pin numbers
Probably best if this is removed
Gaz
goldeneye
stopped looking/posting on VCB years ago.
eden
gaz_powell wrote:ove - I thought this might happen - it looks like you have to be a member of the VCB forum to even view
Shame
Gaz
elitist or what?
ducksta
you dont have to be a member its a open forum like this one
eden
so why cant people see the topic?
You do not have permission to access this thread.
confused!
Edit:
oh you mean you can see the full forum if you join the forum not the club? I see. :oops:
gaz_powell
Eden
That's it you just register with the forum
I think that's how pro boards work (smallframe forum is the same)
Gaz
