Front Variator Starter Pulley
oneday
Keep grinding down front variator pulley's on runner 180.
Appears to be on correctly, torqued ok and not loose but must be rubbing on chaincase.
Should the chaincase have a gasket on which gives the clearance needed to stop this or should i be looking st something else?
e type
No gasket required ....there is either a spacing problem on the front pulley or the belt isn't fitted in clutch proper before you do front pulley up....look on you tube shiney red has a few vids up how to do it properly ..an if you have no spacers on front pulley get some from local dealer simples .....
