What piston was used here
davidblythe
have tried to ask the seller but no replies and sale has now finished
thought it could be 66mm TS185 but compression heights on piston look all wrong and it would have a 3mm packer plate
cant be RM at 66mm
not many pistons at that size without windows
anyone have any ideas
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0335371053
RAP 200
Looks very much like suzuki pe 250 67mm
davidblythe
Okay so 405 PE250/RM250 77-81 18mm small end what rod would he have used APE 110 or topped and tailed the barrell or spacers
do you know the compression height of this piston
regards david
RAP 200
comp height is 37mm,just popped out to the shed to check,ape rod would be best to use,1mm packer,this would make a verry strong cylinder kit.
