Anodising
TED CRUD
After i build my Project engine done i would like to protect it with a coating so i am thinking of Anodising ,i would like to hear the pros and Cons of anybody that has had this done
Smash Ya Pastie
Washington Posse s.c
Train Driver
DigDug
Oddly enough there is an article in Scootering on this this very month! :D
Did you have to do that?
warts
Main scooter: honda
There is a process called Alodizing.
"Alodizing is a simple chemical treatment for all aluminum alloys to increase their corrosion resistance and to improve their paint bonding qualities. Because of its simplicity, it is rapidly replacing anodizing in aircraft work.
The process consists of precleaning with an acidic or alkaline metal cleaner that is applied by either dipping or spraying. The parts are then rinsed with fresh water under pressure for 10 to 15 seconds. After thorough rinsing, alodine is applied by dipping, spraying, or brushing. A thin, hard coating results which ranges in color from light, bluish green with a slight iridescence on copper free alloys to an olive green on copper bearing alloys. The alodine is first rinsed with clear, cold or warm water for a period of 15 to 30 seconds. An additional 10 to 15 second rinse is then given in a Deoxylyte bath. This bath is to counteract alkaline material and to make the alodyzed aluminum surface slightly acid on drying."
Lots more info and even vids on utube .
I had some cast parts anodised on the Guzzi and they turned out a bit fuzzy.
