tie rod gear swivel
weller51
Hi is there a special way of fitting these together ? ? Reason i ask is that my gear swivel won't fit with the tie rod ! ! When you look at my gear swivel the area where the swivel meets the tie rod is not straight so iam wondering if i have to do some fettling to get it to fit ? ?
Did you not see this? only posted a couple of days ago http://scooterotica.org/forum/viewtopic.php?f=7&t=31996
weller51
Ah thanks no i didn't see this so ill have to do the same by the looks of it ! !
