Black Spark Plug
Tabian
Main scooter: GP 200
Hi, after my tea time run of about 60 or 70 miles the spark plug is really sooty, can anybody tell me how to cure it please...?
bristolmod
Clean it? :D
I think you may need to tell us your set up first...............
Scootering since 1968.
Tabian
GP200 with 22mm Jetex carb
bristolmod
Jetex could be the problem- poorly machined?
Main jet to large? Try 118
Jets/ atomisers/ slide. Wrong sizes / poorly made?
Wrong spark plug?
Blocked air filter?
Is bike running OK apart from black plug?
Tabian
Main jet is 118
spark plug Champion N5C for hot running
air filter looks a bit iffy
but apart from that it runs quite well
bristolmod
try an N4 or a genuine NGK B7ES
