Page 1 of 2
Powerjet on Dellorto PHBL 25
Posted: Thu Aug 07, 2014 7:01 pm
by Pepot
Hi! is there any aftermarket powerjet that can be fitted to a PHBL 25? thanks!
Re: Powerjet on Dellorto PHBL 25
Posted: Fri Aug 08, 2014 8:50 pm
by Knowledge
Cam Lam's power jet fits the PHBH 26mm - 30mm, but it might be worth asking them if it can be fitted to the PHBL.
What problem are you trying to cure with the power jet?
Posted: Fri Aug 08, 2014 9:34 pm
by Pepot
Overrich up to a 1/4th throttle, even with a 50 pilot, but perfect past this point. Wonderful on a higway but awful in the city. I guess that some fuel is outgoing through needle and atomiser,so if I fit a leaner atomiser or needle, I'd like to compensate with a powerjet. Thanks for answering knowledge! I've seen the camlam's kit, but is not anounced which carbs fit. I'll ask them.
Posted: Fri Aug 08, 2014 10:19 pm
by rosscla
You need enough room in the throat, before the slide, of the carb to drill and tap the power jet into.
What slide do yo have in?
Posted: Fri Aug 08, 2014 10:54 pm
by Pepot
Its a 40 roundslide.
Posted: Fri Aug 08, 2014 11:46 pm
by byron
try a weaker slide before fitting a powerjet...
Posted: Sat Aug 09, 2014 1:10 am
by rosscla
byron wrote:try a weaker slide before fitting a powerjet...
That's where I was headed 8-)
Posted: Sat Aug 09, 2014 7:35 am
by soulsurfer
I have a CamLam PJ fitted to a PHBL25 on a GT186... It fits fine
Posted: Sat Aug 09, 2014 1:13 pm
by Pepot
Thanks for the advice Byron and Rosscla. Soulsurfer,mine is a GT186 too. With a BGM bigbox V2 exhaust and a BGM ignition with a Khepper programmable CDI. I use a standard airbox W/O strangle neck and a BGM metalic air filter. What are your carb settings,please? Thanks again for your replies!
Posted: Fri Aug 15, 2014 5:20 pm
by soulsurfer
Pepot wrote:Thanks for the advice Byron and Rosscla. Soulsurfer,mine is a GT186 too. With a BGM bigbox V2 exhaust and a BGM ignition with a Khepper programmable CDI. I use a standard airbox W/O strangle neck and a BGM metalic air filter. What are your carb settings,please? Thanks again for your replies!
r
Just seen this, but replied to your pm, feel fee to post the reply here ;)
