Acewell 2856 speedo
Spud
Thinking of getting one of these for the lammie auto conversion i am starting to build soon :D
Anyone fitted one of these speedo's before?
If so what sensor did you use for the front wheel & how/where did you mount it?
Also, have you got it set up to display the water temperature & what temp sensor did you use?
cheers
Spud :?:
wack 63
Main scooter: '71 GP TS1
I've had an Acewell for years and pretty sure it came with a screw in temp sensor to replace a bikes factory fitted one. Can't remember if the speedo one was in the kit but they work different to the normal ie SIP sensors in that they don't face the magnet or bolt head but are fitted parallel . Try Acewell or Quadtech for more info.
