px experts.
oggy
Hi,my electric start stuck on(bad noise),had to disconnect battery on the side of the road,got home now no rear light/horn/fuel gauge,un seized the electric start bit,but now nothing working on the electric start either,has something broken or anythink to replace as ok before it stuck on/px200 2001,any help please
fastfrog
Why did you disconnect battery?
Check your plastic connector in the black box on top of your cooling casing. Seek for any earthing issue....
Size matters!
AndyGatecrashers
Main scooter: Vespa GT210 Vespa T5
Fuse ?
oggy
Had to disconnect the Bat as the noise was still happening even when the scoot was turned off,where about is the fuse ,thanks
gp200ts1
Main scooter: lambretta series 2
the starter relay is probably shot
